Post by lockymac on Dec 26, 2015 1:33:47 GMT -6
Ok so I have a gta 50 I just brought and it sounded like a simple carb clean was all it needed as it was bogging down on takeoff so when I got it home I cleand it out but same ptoblem. I than switched the carb over to the one that was in my old moped which went fine but no luck . I than gave the carb a major clean and checked the reed valves but still had the same problem. I am farmiliar with what happens when you mess with the air filter on these things so I made sure there were no holes or places air could get in except the inlet hole. The odd thing is though after it sits for a while it goes fine and takes off really fast but only for about 30 seconds I have a feeling it may be running to rich on oil as it puffs out a lot of smoke but I don't think that that would cause the problem help!!!!
