Post by menthol on Jul 5, 2016 21:52:33 GMT -6
The grande is a fun bike,,,,just take your time and go thru the carb and she should light right up That's my tomorrow also see what else is wrong... Already saw the blinkers are gone and decompression valve handle and valve are gone I think.. Some plastics need to b replaced buy will get epoxy as I'm broke. Also button up the green scooter and sell it as parts... Lots of new parts I poured money into the Chinese scoot... Fun fun!
Post by menthol on Jul 5, 2016 18:51:54 GMT -6
So close! Had spark now... No fuel. Replaced the petcock/vacuum valve. No go flipping giving up. On to Craigslist it will go... With all new extra parts. Bought a new victim Vespa grande that runs... But not awesome.
Post by menthol on May 29, 2016 13:58:28 GMT -6
This helped a lot! Thank you so much. I suddenly find myself with a lot of time and not much $$ (got canned). So I'll have a bunch of time trying to fix the scoot and look for cheap parts.
I pulled the stator/magneto metal cover thing and found out I have a 8pole 4wire setup? Also tested that my starter button works. But the solenoid does not engage. So I need to buy a new one. While I'm at it maybe a choke.
Might need a new fuel pump?
Post by menthol on May 13, 2016 15:49:54 GMT -6
Hopefully by identifying the scooter I can finds parts to fix it. The story is the following I traded this non running scooter via craigslist. It has a title and all but won't start. The owner said that's the only thing wrong with it. It's green and says Agility on the side along with YY50QT-6. Got it home and it had no battery... I bought a new one. Also got a new plug for it. Put in fresh gas after draining old stuff out and replaced plug. The starter button don't work... (Need new). Kill switch is big ? I tested the spark plug lead and it seems ok with continuity thru it. Starter motor is ok, it cranks when I short the poles on the solenoid. Choke might be bad.... And the stator Can't even get the darn metal spinning thing off.. (Need to buy puller... And stator but what kind 5 or 8 pole 4 or 5 lead). And then there is the mystery box CDI. Get a soured up one to make scooter have the oomph to haul my big butt around. I guess it all starts by identifying the beast.. Adding some photos to help. Also if there are anyone really bored and knowledgable on MN/WI border along I-94 to give me a hand.?..
