Post by cherry250cc on Jun 21, 2010 18:52:13 GMT -6
Just curious what others are getting on this scooter for a top speed. I currently can get it to 63-67 mph (gps). Low? High? Whats yours?
Chas
Post by cherry250cc on Jun 10, 2010 22:53:39 GMT -6
I found the problem  Being that it was only getting hot and melting at that connector, and no where else on those wires, that it HAD to be the connection. I cut that wire, stripped it, and reconnected it as good as I could. Result? No more melting wire!!!! Again, thanks a million for everyones help. Chas
Post by cherry250cc on Jun 10, 2010 10:47:20 GMT -6
OK, I have traced the wires that goes into the crankcase housing from this burnt connector and all look to be fine. What exactly do these wires go into in the crankcase housing anyways?
What is, and where is the stator?
On the other side of the connector, the wires run up the frame to under the cover that hides the fuel tank. I havnt got to remove that yet. What do they go?? I am at a stand still for now as I have to get ready for work.
Thanks guys a million for your help. I'll check back on again tonight. Chas
Post by cherry250cc on Jun 10, 2010 10:07:17 GMT -6
Wow, I found the problem fast. Check out my picture below to see where I found a connector loose!!  I am now presented with a problem that arose a month or so ago when I did my full PDI. After changing all of my vacuum and fuel lines last month I started the scooter up and after a minute or so I had smoke coming from the right rear of the scooter. I seen that the plastic connector was roasted so I re-routed the wire. After re routing the wire, I let it run for 10 minutes or so with no smoking and/or melting. Well when I stumbled upon the headlight solution, I looked at this wire I re-routed and it is again melting and smoking (see pic). I know these three yellow wires go to the top of the engine oil crankcase (??) but what are the other ends of this connected to? Oh, and these 3 wires aren't normal electrical wires with plastic coating its a different type of coating, kind of like its insulated. What can I do to stop this and where does it go to? I finally got my headlight/taillight/cooling fan issue fixed but I dont feel safe riding until I get the burnt wire issue repaired. Thanks, Chas
Post by cherry250cc on Jun 10, 2010 7:58:20 GMT -6
Thanks for the replies fellas!
I did fail to mention that for four months everything was fine. It just started doing all this the other day. I don't want to give any false information but JRR, the fan does come on,,,, only when the scooter warmed up.... just like it should. But in order for it to come on, I have to have the high beams on. If the coolant temp isnt hot enough yet, it will not come on.
Ill strip the plastics down today (sigh) and start looking around. I will report back.
Thanks everyone.
Post by cherry250cc on Jun 9, 2010 22:05:35 GMT -6
OK, I posted this over at scootdawg with no luck. Maybe I can get some luck here.
My headlights wouldnt work the other day. I played around with it and they will work when I keep the "passling light" button pushed. My tail lights and cooling fan works when Im on high beam only. Headlights dont work on either high or low beam, only when the "passing lights" button is pushed.
The 15A fuse at the battery is good. Any idea what i can do? I have the MC54-250B clone.
Thanks guys!
Body parts
by: cherry250cc - Apr 8, 2010 7:55:40 GMT -6
Post by cherry250cc on Apr 8, 2010 7:55:40 GMT -6
Where is the best place online I can get body parts for my Red JCL250?
I wiped out last night and I need a new left mirror and trunk.
Thanks, Chas
