Post by cfmotofashion09 on Sept 5, 2016 10:53:12 GMT -6
If you follow your signal switch wire it should lead you to it I believe you will find it back of you speedometer head. I ordered a new flasher should be here in a few days I will update after the install
Post by cfmotofashion09 on Sept 3, 2016 12:43:04 GMT -6
Is either one of these two relays the flasher?
Post by cfmotofashion09 on Sept 3, 2016 12:39:51 GMT -6
Post by cfmotofashion09 on Sept 3, 2016 11:03:59 GMT -6
Scooters have a blinker relay for signals and 4 way flashers good chance it's gone . Any chance you can refer me where to find one and where mine might be located in my 2009 CF Moto fashion 250t
Post by cfmotofashion09 on Sept 3, 2016 10:50:53 GMT -6
Post by cfmotofashion09 on Sept 3, 2016 10:49:33 GMT -6
Post by cfmotofashion09 on Sept 3, 2016 10:28:34 GMT -6
Okay So yesterday when riding i heard a squeak in the front wheel that would come and go can get pretty loud so I decided to tear the front wheel down trying to figure out what's going on turned out to be the speedometer cable housing next to the wheel the gearing inside needed cleaned and regreasing so that led me to maintenance bike and after I was done I washed it.. (I think thats is here I made my mistake)
Let it set and dry and took off riding and while riding I noticed my turn signals wasn't blinking so I started checking it out all the bulbs seem to be fine except one they are dual filament bulbs And1 filament in the left blinker is busted but that didnt stop the blinkers from working in the past only the left running light.. So I started playing with it moving lights around cleaning sockets looking for loose connections and find nothing..
when I turn the key on both running lights will light up if I try to use them one will go out and not come back on. "on the front"..the rear blinker lights aren't doing anything... If I turn the key off and back on the front lights come back on if I start it up the left blinker will go out and not come back on.. only thing I can think of is maybe a blinker relay?.. but Idk where it is located
Post by cfmotofashion09 on Sept 3, 2016 10:14:02 GMT -6
It is from 6sigmajetkit.com.. I found them on eBay and when you order you give them the specs to your bike they then put together a supposably "custom" jet kit comes with drill bits and jets and lots of directions LOL.. Anyway it doesn't seem like a complicated process.. but my main concern is i dont wanna burn up my scoot because I believe I may have somewhat of a head gasket leak due to the smell of burning antifreeze and the way my cooling system Acts when I gas it for too long
Post by cfmotofashion09 on Aug 26, 2016 22:57:04 GMT -6
I purchased this jet kit off of eBay supposably its for these scoots it come with different size jets and a couple of drill bits has anyone ever installed one before or know if it's even worth it now that I'm ready to install it I'm second-guessing it ..bc I don't want to mess up my carburetor or something else any input is appreciated thanks guys
Also I don't get notifications for some reason but I will log back on frequently hoping someone has replie
Post by cfmotofashion09 on Aug 11, 2016 16:58:21 GMT -6
Thank you so much.. I've already bit the bullet and ordered a used.. (motor mount hinge?)..with a bushing on it....waste of money btw.. (should've known better).. I think I'm just going to make a spacer to take up the extra Slack
Post by cfmotofashion09 on Aug 9, 2016 7:19:49 GMT -6
Post by cfmotofashion09 on Aug 8, 2016 7:44:51 GMT -6
I'm having trouble even figuring out it's General name..pivot bushing,engine hanger bushing,engine mount bushing,?
It's located at the top of the engine and seems to be mounted on a hinge what connects to the top of the engine the rubber bushing is severely dry rotted and shrunken to where it is clearly too much slack and needs replacing
Anyone know parts dealer that would have this?
I have a picture if I could just figure out how to post it
Post by cfmotofashion09 on Jul 11, 2016 6:51:40 GMT -6
Looks like you need to get your multimeter out and use the diagram above in relpy #2 and sort it out one wire at a time. A test light can also be useful but will not replace the need for a real meter. We also have more in our library for reference. If the wires are not completely burned in two, take them one at a time going forward and backwards to where they are still good. As long as the copper is not gone just replace each, one at a time. If they are gone then tracing is the only way. I don't have a multimeter or test light It's just really bugging me trying to figure out what they are for these wires do have two fuses inline... Looks like they run to the usb/radio.... Any thoughts on what they used to run to? I got some good pictures if I could just figure out how to post them I see the Photobucket link and the directions
Post by cfmotofashion09 on Jun 25, 2016 17:01:19 GMT -6
Need to tear dash off again........gotta find where it plugs into? Thanx Bashan! Anyone know where this plug goes? can't seem to find a connection for it
Post by cfmotofashion09 on Jun 25, 2016 12:31:46 GMT -6
I recently bought a 2009 cf Moto fashion. It has 1700 miles on it. It has been sitting for about a year. I emptied the gas tank ,changed the fuel filter and when taking the pipe from carburetor to air cleaner I noticed a group of wires that run to the rear of the scooter has burned. It looks like it touched the muffler. If I knew how I would post a picture. One wire is red , one is yellow and there is a large black and a small black wire that doesn't unplug like the red and yellow. wire. The scooter starts on starter fluid but won't stay running. I removed the screw on the front of the float bowl, but no fuel came out I know this is an Old Post hope someone answers did you ever figure out what these wires go to I looked at the post of the wiring diagram but I can't really zoom in and figure it out I'm having the exact same problem on the exact same you're making model the little USB plug-in in my glove box is not working looks like it's connected to those wires but I can't find where the burnt end connects to
