Post by mason2102 on Jul 15, 2021 15:07:12 GMT -6
My gy6 wants to go when you stop...even at low idle. I took cover off an inspected variator and weights...all seem ok? Do you think the clutch is going? If you ride it seems just fine....just wants to go at idle.....something is not freeing up! Thx for anyone's input.
Post by mason2102 on Jun 15, 2017 18:50:38 GMT -6
bump?
Post by mason2102 on Jun 9, 2017 14:49:13 GMT -6
Here is what I got with stator in scooter.... pick-up wire 146 ohms....cranking it getting about 2.4-2.5 vac red/black wire 0 ohms...but cranking it getting about 72 vac battery is starting to go down a bit....the 0 ohms I don't get with it producing 72vac? ![???](//storage.proboards.com/3059616/images/uQfospbezE7IcMUG1AtY.gif) ? I changed stator last year...tried another I had laying around....changed coil...tried a different known working cdi....grounds seem good....and suggestions are appreciated!
Post by mason2102 on Jul 18, 2016 12:55:55 GMT -6
I put new stator and voltage regulator in and still only getting 12.6-12.7 volts to battery!.....any other ideas?
