Looking for some wiring help
Post by jkdsteveo on Aug 5, 2016 10:53:28 GMT -6
Wasn't looking for diagrams, just explanations Problem solved
red to black = ignition blk/wht to grd= kill grn/yellow to red/yellow=start
thanks
Post by jkdsteveo on Aug 4, 2016 18:05:55 GMT -6
I've got a similar issue. All lights have been removed from my scooter There are no brake switch connections either. It was that way when I got it. Everything else is connected except the following wires
red wire that ran to old keyed ignition switch black wire that ran to old keyed ignition switch black/white that comes from the stator, and runs to cdi, and has a soldered black/white feed connected to nothing I also have a red/yellow, and a green/yellow that are connected to solenoid, and are connected to nothing
I don't have $ for new wiring harness, and just want to wire it up to run with switches
So I think this is right Wire a switch between black, and red for ignition on/off Wire a switch between ground and blk/white wire for kill switch Wire a switch between red/yellow, and green/yellow for start switch
Does this sound correct?
thanks
