Post by bb3 on Oct 10, 2016 19:32:04 GMT -6
Wow, thanks! That is super helpful (and much simpler than I would have anticipated).
He mentions quite a few combo's for the distances. 3 thou on both, 4 thou on both, 3 on one, 4 on another, etc. Is there any way to figure out the 'best' setting for my GY6 without having to try one setup, then run the engine, then take it apart and try a different set up, then run engine again and see what is better?
Post by bb3 on Oct 10, 2016 17:59:22 GMT -6
Thanks!
After a few more cold startups, it looks like in most cases it needs a gentle tap on the gas to start while pressing the ignition button, in addition to 5-10 minutes of idle time to really be in great running shape.
Post by bb3 on Oct 10, 2016 10:31:13 GMT -6
No idea what valve lash is, but I will google it!
Oil level since changing the oil and replacing the gasket has held steady with no noticeable leaks!
Let the engine idle for five minutes before getting in this AM, has been working like a champ, no more smoke coming from the exhaust.
Post by bb3 on Oct 9, 2016 15:11:43 GMT -6
Cyborg, that may be what happened!
I also picked up a new spark plug, CDI, and ignition coil from the same dealer I got the gasket from.
Turns out the CDI had different terminal adapters, so I couldn't hook that up, but I was able to install the new spark plug and ignition coil, in addition to replacing the gasket.
Engine started up and was a bit rough, but after 10 minutes or so of gentle driving it was much smoother. There were a few times it shut off with moderate gas, so I would just let it sit for two or three minutes, start it up again, and try again.
Not sure if the bogging down with gas was due to the fact that it was still getting rid of everything from start up, or just because it was cold, but having gotten it started and running, I am much happier and will run more tests tomorrow.
Post by bb3 on Oct 8, 2016 20:27:03 GMT -6
Thanks tvnacman, I found a local supplier an hour away I am meeting tomorrow for the part. Maybe next time!
I still don't know the reason it won't start, but at least this might solve the oil leak!
Post by bb3 on Oct 8, 2016 17:23:54 GMT -6
UPDATE: Decided to take the valve cover off as I was stuck with all other troubleshooting methods. Here is a pic of the gasket: imgur.com/vdSS3rYAnd a close up of the blemish: imgur.com/dSjygOxNew gasket is on the shopping list!
Post by bb3 on Oct 8, 2016 11:42:19 GMT -6
Hi folks! Thanks for the replies! If I remove the valve cover, will engine oil spill out (or any other fluids?)
Post by bb3 on Oct 8, 2016 7:31:08 GMT -6
I just got a new taotao myself and one of the headlights wasn't working.
Did you check the electrical connections? It will be a pain, but you might need to check each wire and terminal from the headlight to the battery to make sure no wires have come loose (some of mine had and needed to be re-crimped). Also there may be a fuse somewhere in the electrical box that blew and needs to be replaced.
Post by bb3 on Oct 8, 2016 7:17:41 GMT -6
Thanks in advance for your help, and I apologize for the 'bullet point style' message but I am a bit flustered. Brand new TAOTAO 150cc GY6 engine powered go kart. Tested oil levels prior to start up, they were near the upper level of the hash marks. During start up, exhaust smoked heavily. Assumed it was part of start up, let engine warm for ten minutes, still smoking, drove very slowly on paved neighborhood roads for one minute, still smoking from exhaust, then engine stalled when I let off gas during a slight downward slope. Pushed back home, and checked oil again, much lower (lower hash marks). Leaking visible when I get under scooter. Remove shroud, this gasket practically falls off. It looks like oil is coming from here. (Pictures below) So just a few questions, it that gasket just to keep the shroud from rubbing on the metal, or is it a badly installed valve cover gasket? If it is just a 'plastic on metal barrier gasket' should I just order a whole set of gaskets and start with the valve cover and see if that helps, because something is leaking, for sure. The main question I have is if I ruined my engine. Will fixing the leak (wherever it ends up being) and adding more oil allow the engine crank? I don't see how those things alone would allow the engine to start turning over if it is not turning over now (since that stuff is all just mechanical, right?), unless there is some safety that prevents start up based on low oil level? I am hoping this is the case, but I don't know enough about these engines to know what kind of protections they include. If I have ruined my engine, and fixing the leak and adding more oil will NOT help (maybe I have seized the engine?), what are my options then? Are there any resources for rebuilding an engine? I purchased from a dealer with a warranty, and am waiting to hear back from them, but I need to get all my ducks in a row to handle this on my own if they tell me to kick rocks. Thanks again for your help, and like I said, I am a bit flustered so I apologize if anything is coming out as gibberish or not explained well. Video of startup: drive.google.com/open?id=0Bx8zAFJkqoUic3ZvdXlJZVRnYmMPic of leaking with shroud: Shroud removed, this gasket is flopping around:
