cool and not at all egostistical
Post by jackrides on Jun 30, 2017 12:28:54 GMT -6
I think the only difference is trim and headlight. My 1 year cy50a has 5500 miles with no major issues but a number of small ones and next to no support or wiring diagram. 20 20 hindsight tells me to go for 12" wheels. Good luck!
Post by jackrides on Jun 2, 2017 22:09:53 GMT -6
How are you checking the system? I always start with connecting the black (negative) of my tester (it can be a light, or a meter; a light is great and easy for first stage testing) to the negative battery terminal. Next, of course touch the positive bat. term. . If ok, then follow the hot wire thru the system. Older models use the frame(or engine cases) as ground instead of a separate wire. Check if the negative bat. term. has voltage (or the light goes on) between it and the eng. case or frame. If so, the ground connection between the bat and the rest of the machine is bad.
Post by jackrides on May 31, 2017 10:51:59 GMT -6
Sometimes installing a plug in an awkward place can result in the socket canting and cracking the plug. It doesn't always fail to spark immediately. I will never admit to making such a newbie mistake. If the socket doesn't have a rubber insert, make one with duct tape. Wrap a plug with it, sticky side out, then finish with a wrap of smooth side out. Get to the point, trial and error, where it will just push fit into the socket. The smooth side out means it can be easily removed and reused. You have just made a custom special tool!
Post by jackrides on May 27, 2017 14:44:53 GMT -6
It would be great to hear members results from 'hi-perf' cams. Please mention other mods.
Post by jackrides on Feb 12, 2017 12:46:54 GMT -6
First class! Doing same on my Tao-Tao 50. Adding a few marker lites also. Not sure bout the led headlights, as this scoot does not have the well shaped reflector the higher end scoots have. Keep you posted.
