Post by chong49cc on Aug 5, 2017 20:22:39 GMT -6
I installed a JCMOTO 125cc Engine 4 Stroke Motor on my 49cc Chongqing. Everything worked great except when I turned the lights on they seemed normal until I gave it gas the bulbs went super bright and popped. The speedo lights did the same. Is there parts I need to change when going to a bigger engine like that? All the wires were the same except there was a pink wire coming off the engine. Any help would be great, thank you
Post by chong49cc on Jul 28, 2017 20:59:44 GMT -6
So I tried to but a 110cc cylinder jug and head on my 49cc Lifan engine. the timing chain and connecting rod are to short. is there anything I can do? I asked all the questions before ordering from Amazon. Its like less than a half inch off but that's a lot if it wont work
Post by chong49cc on Apr 28, 2017 15:34:09 GMT -6
Wondering if a big bore kit is really plug and play? Or will I need to get a new carb for it to really work?
Post by chong49cc on Apr 21, 2017 20:28:30 GMT -6
Post by chong49cc on Apr 19, 2017 2:20:38 GMT -6
Kind of new to the 49cc engine. I have no low end power. Correct plug gap, fuel, clean air filter. I can hold it in place with feet on the ground when giving it full throttle. Once it is moving I can do 42-43 mph. It runs great once warmed up(really cold blooded). I know its a small cc but I would think it would have a little power:) link
chong
by: chong49cc - Apr 19, 2017 1:57:10 GMT -6
Post by chong49cc on Apr 19, 2017 1:57:10 GMT -6
Post by chong49cc on Apr 19, 2017 1:55:17 GMT -6
Post by chong49cc on Apr 19, 2017 1:42:47 GMT -6
chong
by: chong49cc - Apr 14, 2017 12:39:11 GMT -6
Post by chong49cc on Apr 14, 2017 12:39:11 GMT -6
I tried to post a pic of my bike. no luck. I don't get it. and I am pretty good at following directions that were givin
chong
by: chong49cc - Apr 14, 2017 12:37:15 GMT -6
Post by chong49cc on Apr 14, 2017 12:37:15 GMT -6
Post by chong49cc on Apr 13, 2017 14:56:56 GMT -6
Cant seem to upload a image of it
Post by chong49cc on Apr 13, 2017 13:58:56 GMT -6
Is turning a 49cc into a 110cc as easy as the interwebs make it out to be?
Post by chong49cc on Apr 8, 2017 14:53:45 GMT -6
I thought expansion as well. when its really low on gas and you fill it. you can hear bubbles but idk. I guess the simple answer is not to fill it up as much.
Post by chong49cc on Apr 7, 2017 0:47:40 GMT -6
2010 chongquing 49cc. When I fill my tank it will over flow out the filler neck after sitting for a few minutes. Does the gas expand? I can figure it out
