Post by vino125 on May 3, 2017 11:26:51 GMT -6
I have a 2004 125 Vino - 4 stroke, 1 carb...
I recommend the following:
1) Change the spark plug first off! 2) Clean the carb jets, including the accelerator pump with carb cleaner. 3) Use compressed air to clean the jets (in my case), as well as any crevice/channel and the accelerator pump.
My scooter was running poorly 4 years ago - and I suspect now that it was because of the faulty spark plug... After sitting with bad gas, things came to an almost end for that scooter... I'm wising up finally. Now on to my CB750 with 4 carbs that hasn't run in years...
Good luck all - remember to always start with a fresh/new spark plug...
