Post by zander09 on Jul 31, 2017 11:19:55 GMT -6
I'll check the vacuum lines. Is there readily available fuel pump for this thing I could substitute if needed? What is the whitish thing under the seat? I see fuel being pumped into it as i crank the engine. It will only crank if jump across the starter seloniod. All the lights work with the key.everything is connected. But the key can be left in the house. Not needed to crank the engine. The one thing that doesn't work is left brake handle won't turn on the brake light. The right on will. I don't need to hold either one to jump crank it. Thanks in advance for any leads. Ed
