Post by isayork99 on Mar 8, 2018 3:09:34 GMT -6
Thank you for the information , But what you are saying is that a long case cover off a 150cc motor is the same as a long case cover on a 50cc motor. I have found a lot of measurements and the best i can find is a 2mm difference.
Post by isayork99 on Mar 4, 2018 13:02:27 GMT -6
I have found a clutch cover i really like but it is made for a 150cc engine and from what i have found is that engine from corner blot to corner bolt is 363mm=14.3". But I have a 50cc engine and from what i found is that cover is 361mm=14.2". BUT that could be the difference in where the measurements we taken from end to end or center point to center point. Has anyone test fit or put a marked 150cc case on a 50cc engine or know if the Chinese would really make a 2mm difference cover?
Post by isayork99 on Mar 4, 2018 13:00:28 GMT -6
Post by isayork99 on Feb 6, 2018 7:13:02 GMT -6
I have found a clutch cover i really like but it is made for a 150cc engine and from what i have found is that engine from corner blot to corner bolt is 363mm=14.3". But I have a 50cc engine and from what i found is that cover is 361mm=14.2". BUT that could be the difference in where the measurements we taken from end to end or center point to center point. Has anyone test fit or put a marked 150cc case on a 50cc engine or know if the chilies would really make a 2mm different cover?
