Post by tgblife2006 on Apr 20, 2018 13:52:00 GMT -6
It is a thick black cord hanging from the right side. It's in the back near the engine and the foot peg for a passenger.
Post by tgblife2006 on Apr 20, 2018 12:23:25 GMT -6
There is a black cord hanging on the side where the engine is. It looks like a power cord for a old radio. Does anyone know what that goes to or if it's the ground to the engine?
Post by tgblife2006 on Apr 19, 2018 14:52:05 GMT -6
I bought a new CDI unit and that wasn't the problem. I checked to see if the spark plug was getting spark and it's not. Before I had this issue the bike was dropped but it cut on briefly after I cleaned the carburetor then shut off again.
Post by tgblife2006 on Apr 19, 2018 14:46:46 GMT -6
The hose that wasn’t connected to the carb is probably the air cutoff valve, generally keeps you from having backfires upon deceleration. It could be the cdi, but I’d check if the spark plug is getting spark first. I’d also see if the carb is getting gas. You can read this article from Allyoop on how to check that - scooterdoc.proboards.com/thread/7723/check-fuel-delivery . Check those 2 things before spending money on what could possibly be the wrong thing. Solymar
Post by tgblife2006 on Apr 17, 2018 18:14:39 GMT -6
So I replaced the fuel filter and it cut on briefly then it wouldn't turn over again. Could it be the CDI unit?
Post by tgblife2006 on Apr 17, 2018 18:12:29 GMT -6
It looks like it doesn't have the fuel filter in. There was a hose missing that connects to the carburetor so I don't know how it was even running before but I replaced the hose and cleaned it,I also replaced the spark plug.
Post by tgblife2006 on Apr 15, 2018 6:27:34 GMT -6
Post by tgblife2006 on Apr 14, 2018 20:29:35 GMT -6
I have a 2006 tgb moped I just bought used. I went to ride it and it started to stall after I picked up speed but now it's not turning over. I changed the spark plug but it still won't start.
