Post by jd50i on May 8, 2018 13:54:01 GMT -6
I'm needing a few screws to finish a scooter I got in a box. Getting to the end and finding some hardware is missing. Screws for the battery box, the battery strap, screws on each side of the steering neck that holds the plastic, 4 flanged nuts to hold the storage box that is under the seat. The IPC I have shows the screws as the following;
Screw, Tapping ST4.8×16 need 4 Flange Nut, M6 need 4 YY50QT015006 Fixing Strip, Battery Bolt, M5×16 need 2
I could also use a throttle tube.
Post by jd50i on May 6, 2018 9:09:46 GMT -6
Thanks guys. I got it all together and it fired right up.
I need to find break in procedures since the top end is all new. I also need to find some missing hardware, nuts to hold the storage box under the seat, screws for the battery cover, the battery strap, the screws on either side of the steering head that hold the headlight plastic on. Any body have extras?
Post by jd50i on Apr 30, 2018 15:10:56 GMT -6
Odd that the information I have found shows PAIR on bikes with EGR and this one doesn't have EGR. Who knows, PO might have removed EGR although there are no blockoffs. Thanks for the reply.
Post by jd50i on Apr 29, 2018 13:10:16 GMT -6
I have a 2014 Jonway YY50QT-6 that was given to me disassembled with a bad motor. I have the engine back together but still waiting on intake and exhaust gaskets. I am trying to get the rest of it back together but since I didn't take it apart it has been trial and error. Right now I have rubber hoses going to what appears to be a PCV valve, the letters PCV stamped on it gave me the clue. Two hoses come out the back and one connects to the intake (I have 2 ports on the intake) before it goes into the head and the other connects to the airtube between the air filter and carb. The other side has 2 different size nipples but I have no loose hoses to connect to them. Any ideas or is it just open? I also have a rubber hose coming off the muffler and ending. Any ideas or is it also just open? It is the one hanging down by the center stand.
