Post by urbanista on Jun 10, 2018 18:55:02 GMT -6
Hi, you may need to get a 7-pin rectifier-regulator. The r-r had to match the startups you have. If your stator is 11-pole (3 yellow and one green coming off it), you likely need the 7-pun r-r: three yellow coming into the r-r groom the stator; 4 (green, white, black, and red) coming out of the r-r to per the starter, choke, and headlights. I tried this thread back in August of last year, but got 0 response, so I thought I'd try again! I have an 11 pole stator with the customary Black/Red and Blue/White connections; and the other wires are green, white, ONE YELLOW, and pink (4-wire connector). I intended to go to a 6-pin R/R, but my question is; what's the best way to tie in the single yellow from the stator to the THREE yellows on the R/R (or am I missing something)? The Green, White and Red wires on the new R/R replace the same color wires from the original R/R, right? The only other option is if the Pink and White wires from the stator are the same as the two yellows on a "normal" 11-pole stator, is that possible (I know how much the chinese enjoy swapping colors on us decadent Americans)?
