Post by bradley113095 on Jan 3, 2019 20:07:15 GMT -6
Yea I think your on it,,,I'd do the starter first myself,,sounds like the solenoid but hard to tell without having my hands on it Changed starter and solenoid still same issue could it be timing
Post by bradley113095 on Jan 1, 2019 9:54:50 GMT -6
Battery fully charged?,,I'd be checking all electrical terminations,,,especially the battery to frame ground connections and all starter related connections,,,also it wasn't clear is this a new engine in an existing buggy chassis? If it is I'd be suspect of the solenoid being /going bad,,,turn on the ignition and use a large old screwdriver and cross the terminals of the solenoid ,,it should turn over,,if not pull the plug and see if it'll turn over ,,it should spin pretty fast,,,if there's still trouble it may be the starter I'm using an existing buggy chassis without sparkplug it spins fast I had motor spinning fast with sparkplug for a couple seconds I'm gonna try swapping the relay i also have another starter from the howits motor Maby its stronger
Post by bradley113095 on Dec 31, 2018 23:04:58 GMT -6
Will I have too put gear oil in New motor I bought from ebay I know them packages get moved around alot
Post by bradley113095 on Dec 31, 2018 23:03:01 GMT -6
Will a new motor come with the gear oil inside or do I have too put that in it
Post by bradley113095 on Dec 30, 2018 17:30:16 GMT -6
So I just bought a brand new gy6 150cc and I hooked up very thing too my buggy tomberlin cross fire wiring harness I checked for spark I'm getting spark so this what happens the motor will only turn over once then struggle to turn over then turn over again I have extra cdi should I try that I can't kickstart can any body help me
