Post by linuxlover on Jun 7, 2019 15:49:38 GMT -6
Ok, I'll have to try that when it's cold. It's been ok now since it's warmer outside. I'm almost positive this thing has never had the valves adjusted & it has over 1,000 miles on it. Would that have an affect on it starting cold? Thanks
Post by linuxlover on Jun 3, 2019 10:41:22 GMT -6
I got a new auto enricher & put it on but didn't help, still doesn't want to start when cold. Other suggestions?
Post by linuxlover on May 13, 2019 10:44:42 GMT -6
Is there a way to test to determine if it's bad?
Post by linuxlover on May 12, 2019 19:36:57 GMT -6
I have a Roketa Mc-02-50b that was sitting for 2 years. Took the carb out twice now to clean it. Got a good battery, new fuel filter, good spark plug. If you take the large hose to the air filter off and put your hand there it will start right up when cold. It's gotten to the point now where if you give it gas quite a few times between hitting the start button, it will eventually start but it doesn't want to stay running. The choke does nothing when the key is on. Once it's warm it starts up and runs great. Any help would be appreciated.
Post by linuxlover on May 5, 2019 11:39:10 GMT -6
I have the same model as Sammy1 and it won't start. Took off the carb and cleaned it, but still won't start. Any help would be appreciated
