Post by ezed1 on Jun 21, 2021 17:41:21 GMT -6
Newbie back after a year or so , I went with no grease i cleaned out the old stuff coated the inside with graphite stray and went to sliders, haven't had any issues
Post by ezed1 on Jun 21, 2021 17:34:14 GMT -6
Newbie back after a year or so with a little more knowledge Auto fuel tap (valve) diaphragm sits on the side of the carb a vacuum line is attached to it if you open up the top there is a spring and a small diaphragm inside :-) Fuel pump was working just fine
Post by ezed1 on Aug 25, 2020 8:35:41 GMT -6
Post by ezed1 on Aug 25, 2020 8:35:14 GMT -6
Post by ezed1 on Aug 25, 2020 8:29:09 GMT -6
Post by ezed1 on Aug 21, 2020 18:02:08 GMT -6
Had anyone updated their display?well I got tired of minds and it's old inaccuracy, here is a teaser not yet finished
We'll I tried to upload a image but it got to 55% then had a miscarriage 😕
Post by ezed1 on Mar 3, 2020 19:52:30 GMT -6
Get a manual one ,,,Yamaha raptor fits I believe ,,yes fuel in vacuum line means bad diaphragm in the valve not going to work I have,a Jonway sl250 also I'm a little confused about how peacock works minds works like a pump with each strike of the piston the pedcock shoots fuel so trying to use a mouth as some videos i have seen to check is a no go for me also I'm finding there is a lot of differences of opinions PEDCOCK,VARIATOR GREASE OR NO GREASE ETC ETC 😕More like trial and error 😞it being new to me
Post by ezed1 on Mar 3, 2020 19:25:10 GMT -6
I'm way behind the curve but is grease a reference or necessary? Minds was packed with grease and my belt had it on it as well 😕😡so I went with out grease so the question is do I still need that cover? This is a project on the center stand I have not rode it yet 😑
Post by ezed1 on Feb 28, 2020 14:12:51 GMT -6
i just replaced that one and a day later its showing fuel again .could it be coming from anywhere else or the new valve has failed as well?
Post by ezed1 on Feb 27, 2020 12:57:28 GMT -6
Cyborg i replace fuel pump yesterday and toddy im starting to see trickles of fuel in vacuum lines again :-(
Post by ezed1 on Feb 27, 2020 7:23:00 GMT -6
2008 Jonway 250 to my surprise I open it up and A COVER with a seal and GREASE dark in color and sticky😕 ,I thought these things were suppose to be dry ,wasn't sure what to do so I cleaned it out really good and put back together with no grease, any thoughts ? Also there are rubber or plastic seals in the openings where the slide goes,I assume there to keep grease from coming out but it slows down the slide ,I did lube up the slide with some Magnalube i had laying around loosen it up quit a bit,mind you this is a project that i have not road yet everything i have done to it have been on its center stand ,fluids carb clean and currently trying to tune the carb with its no access air fuel ratio screw :-( forgot to mention that the grease seam to not serve any purpose because all of it was slung up and,away from the roller areas which were actually dry 😕
Post by ezed1 on Feb 26, 2020 23:10:35 GMT -6
Post by ezed1 on Feb 25, 2020 22:40:41 GMT -6
Auto fuel tap (valve) has a hole in the diaphragm,,,time for a new one Thanks got one in order👍
Post by ezed1 on Feb 22, 2020 7:37:00 GMT -6
nEWBIE hERE Im seeing small amounts of fuel in my Vacuum lines any help would be appreciated
Thanks
Post by ezed1 on Feb 20, 2020 18:39:49 GMT -6
Picked up a neglected sl250 had a electrical short took care of that cleaned carberator currently flushing radiator and changed gear and motor oil, I up graded the fuel and vacuum to clear hoses and I have notice drops of fuel in the vacuum line is this normal or reason to be concern pedcok or carburetor? I have only ran it on the center stand ,it will idle 2???rpms during cold start then slowly drop 10 15 mins temp alittle below the half mark to a point where if I don't adjust the idle screw it will cut off Newbie here 😆 but very good electro mechanical with me hands Thanks Also the air fuel ratio screw on these in a bad spot would be nice if somebody would machine a adjustment screw that you could get you fingers or something on it to turn or I'm I missing something 😕
