Post by 954insul8r on Dec 14, 2020 14:57:28 GMT -6
Have you checked (tested) the fuse inside the battery compartment? I know you said the battery was new, but can you test it with a mulit-tester? Look for 12 volts and above. The fuse inside the battery is fine & I'm getting over 12 volts when I test it with the multi-tester. I still haven't figured out yet but I'm leaning towards bad ignition or kill switch related although it's just an educated guess at this point. Any help is appreciated and I thank you for taking the time to give any input.. thanks again
Post by 954insul8r on Dec 10, 2020 20:06:23 GMT -6
I have a GY6 -2014 Bash Peace Sport 150cc scooter it hasn't been started in about 4 months give or take . So approximately 4 months ago the throttle tube cracked from cheap plastic in the florida sun but other then that it ran great. That said it sat longer than expected now I finally got to fixing it. New throttle cable and throttle assembly which I upgraded so no more plastic , I also put a new battery in just because.. Here's my problem turn key on nothing happens and I mean nothing. No electric start, won't kick start , no tail light on or hazard lights, or blinkers absolutely nothing comes on .. I'm new to this and I'm at a loss!!! I'm hoping that someone here can tell me what it could possibly be?
