Post by kenasun01 on Feb 21, 2021 5:25:10 GMT -6
yes just make sure the housing is the same as yours and connectors match
Post by kenasun01 on Feb 21, 2021 5:01:09 GMT -6
If you to make a simple kill switch get a 2prong on off switch look where you want to mount it from the switch one goes to engine ground the other goes to the coil ground so you pull the green wire off the coil cut wire 3-4 inches above the connector now you strip end of wire go back to your switch run the other wire to the green wire you just spliced then plug the wire back on the coil ground and there you have your kill switch you must remember every time you start you bike you must switch to on or no spark cause no ground. Hope this helps
