Post by thinkgy6 on May 7, 2011 8:46:08 GMT -6
Hey Guys I am new to this.. Was hopin to maybe find a lil help w/troubles that I am havin. I live in Indiana. I own a Yamati Strada 150 Chrome edition.. Havin starting an problems w/idle.. Scoot seems to run good down the road, but now ,,when I go to start it,sumtimes it does not wanna crank by battery an have to kick,other time's cranks fine..Now always seem to have to give throttle to get to start,either a lil or sumtimes WOT.The idle is irratic. Sumtimes fine others too high or too low..it jus seems to vary.. Starts fine sumtimes cold an idles fine others it starts out fine at 1st but then will keep dying ..HELP..I am lost an confused w/ this b/c it used to run fine.. This all stared when it started leaking fuel out bottom of carb at the bowl drain. this carb does not the drain screw but has the ert type thing w/hose linne attached with drian thing on end of it. the hose was all cracked an leaking..So...I fixed the leak,,put new NGK plug in it,,Change the oil,,I use Mobil 1 15/50,,,an also added bout 1 oz of carb cleaner to the fuel since it sat allot of the winter,,,,NOW since I did all that,,havin major problems w/ the above mentioned...... PLEASE.. any help or insite on this would be GREATLY appreciated
