Post by gregmp on Jul 10, 2023 17:15:31 GMT -6
Greetings all, I recently acquired a 150cc / GY6 scooter. It currently has no spark. I've put a meter on the battery, brake switch, stator and start relay and they check out as ok. The coil was questionable, so I have a new one coming. Hoping that will make a difference. Possible relation? The "kill switch" on the right handlebar currently allows the engine to crank in either the "on" (rotate) or "X" (non-rotate) position. Hmmm. Is this typical? Or, should it not rotate at all in the "X" position? If the new coil doesn't improve things, I'll check the "CDI" unit. One step at a time. Thanks in advance for your input!
