Post by Wantan on May 9, 2024 12:03:59 GMT -6
I’ve got a 2008 Qlink Pegasus I bought used. I bought it not running and without a battery. It was obvious someone had already been into the carburetor, because the intake boot was wedged off of it into the side. Also, one of the bolts that bolts down the intake manifold Is sheared off. I also got a Q link sienna with the scooter, the carburetor for the standard GY6 engine would not fit the Pegasus. After a ton of searching, I finally found one that appears to be the correct carburetor, but I have not been able to find a rebuild kit for it. Does anyone know where I might be able to find one? It’s a: Mikuni BS26-1242 I found one one the alpha-sports.com/cfmoto_parts.htm?q=cfmoto-parts-catalog Website, but only need a rebuild kit. I cleaned the carb and pulled some o-rings off the junk carb from the Sienna. It sounds like there’s an air leak. It’ll start and run, after it’s revved up it’s very slow to come back down to idle. Any suggestions or cross reference of a carb kit that would work?? Thanks
