Post by sailorman on Apr 14, 2013 22:16:29 GMT -6
Starting over again Left brake lever held, key turned to on, start button pressed, engine goes through the motion but will not start. New NGK spark plug installed grounded against scooter frame showing blue spark gaped at 0.24. checked and cleaned carburetor bowl and jets/screws with guitar string replaced carb and still engine will not run. Check spark plug and it is dry as a bone. Starter works fine goes through the motion, battery is new, lights all work. Looking to the lower transmission noticed transmission gearbox drain plug missing near rear tire. (small one not the fill bolt). Anyone know what size this bolt is? Honda dealer is 75 miles away.
Post by sailorman on Apr 13, 2013 23:23:44 GMT -6
Picked up a white 99 Honda 80 for $100 doesn't run, replaced ngk plug, drained old gas, cleaned carb twice using guitar string on jets, carb bowl fills with gas, ground new ngk plug against the frame getting blue spark, have compression, install plug turn key depress left brake lever and no start, check plug, it's dry !!! WHY? Any ideas would help
During further investigation noticed oil drain bolt missing, can someone tell me what size bolt head this is and how long it is, so I can replace this on my own. still cannot start engine.
Post by sailorman on Sept 27, 2011 22:18:46 GMT -6
Retired from the Navy with 21 yrs would do it over again if they hire old people. Went in young came out old, now I manage a marina in the Pacific northwest. Could never ask for a better job.
