Post by gaurdian101 on Jun 29, 2011 20:43:09 GMT -6
thanks cruiser I'm new to this scooter stuff and you guys make it so much easyer to fix things thanks so much...
Post by gaurdian101 on Jun 29, 2011 18:22:32 GMT -6
ok guys here is another thing I need help on..... man you guys are better than family when it comes to getting help on anything....but I noticed and this might just be normal but my electric choke on a mp 250a pcl when it's running you grab the sencer for about 8 sec you have to let go of it....It gets that hot is this something to worry about and if so can I cut the wire and put a switch on it so when I need it.... does that sencer have to be on all the time to work....thanks guys for your help
vince
blow by
by: gaurdian101 - Jun 29, 2011 8:40:32 GMT -6
Post by gaurdian101 on Jun 29, 2011 8:40:32 GMT -6
I found the problem well I hope I did....I took the carb out to clean it thinking maybe something wrong there will cleaning and taking out and put back in the chineese vacuum hoses have cracks in three of the line to the carb so replace with american hose oh my drove the thing 120 miles last night not a problem.....it stalls if you come to a stop from coming down from high speed but I can live with that a little more fine tuning and I'm doing some fun runs.... thanks guys for all the help....
vince
blow by
by: gaurdian101 - Jun 27, 2011 18:52:26 GMT -6
Post by gaurdian101 on Jun 27, 2011 18:52:26 GMT -6
it only has 340 miles on it and I just fineshed the valve job was a little tight but not bad still not running right haven't tried the spark plug just asumed it was still good I didn't think of that. Got a new filter to and cleaned the carb out....thanks for the info trying the new spark plug it's a work in progess but don't mind and agian thanks...
blow by
by: gaurdian101 - Jun 27, 2011 15:27:11 GMT -6
Post by gaurdian101 on Jun 27, 2011 15:27:11 GMT -6
I have a mp 250a pcl and it's not running just right I've tried the carb the floot everything found a cracked hose on the carb and thought that was an easy fix still the same but the problem is that it get going and it seems to stall and starve for fuel and cut's out allot and don't get up to full rpms and I noticed when it was running if the oil cap was a little lose it had allot of blowby a lot of air was going out to the crankcase is this normal or does it sound like it needs rings or valve ajustment? any help would be most help full thanks vince
Post by gaurdian101 on Jun 11, 2011 8:09:18 GMT -6
Hi guys I'm just brand new to this and I got a mp 250a jcl scooter that I just bought has 36 miles on it and seem to have a carb problem the air fuel mix is off and I can't find anything on how to ajust the carb if anyone else had the same problem please feel free help a friendly hopfully riding scooter fan thanks vince
