Post by sarge707 on Aug 9, 2011 15:17:11 GMT -6
Hope to ride soon , will check the back tire after I get he pipe back on.
Post by sarge707 on Aug 6, 2011 10:43:36 GMT -6
Air compressor and WD40 got the pads open. Thanks!
Post by sarge707 on Aug 5, 2011 13:03:38 GMT -6
Got the pads open but had to bleed the line then blew airfrom my tire compressor and then the WD40 and a flat blade screwdriver and Little by Little they opened and I cleaned them off good Soo now to review the excellent 2 part Video on changing the fluid and bleeding the lines! Thanks Again! Too Hot to ride anyway?
Post by sarge707 on Aug 4, 2011 10:04:40 GMT -6
Yeah- I opened the bleed valve and oil reservoir and still no luck with the piston? Gonna get the C clamp and have to rebleed the lines BUT I ,m learning and in no rush. Gonna find some video,s on this~!
Post by sarge707 on Aug 3, 2011 16:01:00 GMT -6
That person touching the brake was probably ME. LOL If I open the resevoir I won,t have to bleed them will I?
Post by sarge707 on Aug 3, 2011 15:26:52 GMT -6
I,m putting back the swing arm after replacing rear tire on my Reverse Trike and the Brake caliper seems closed and will Not slip on the silver plate so I can re-bolt it? Any Hints? Thanks.
Post by sarge707 on Aug 3, 2011 15:24:13 GMT -6
Got tire changed and putting back on BUT Brake caliper seems to be stuck closed Sooo how do I get it open so it will go over disc??
Post by sarge707 on Aug 2, 2011 15:47:03 GMT -6
I did it today. Its simply a 10mm hex bot opening -I unscrewed it with a beam torque wrench- under it are 2 washers- swingarm-2" spacer -rim and driveshaft. Progress!!!
Post by sarge707 on Aug 1, 2011 15:04:15 GMT -6
Sent the Pic to Kelly at Scooter Depot after trying to explain for an hour!!!!! A round cover that the 3 bolts attaches to covers whats inside on the picture.
Post by sarge707 on Aug 1, 2011 12:46:33 GMT -6
I did PM him a while ago. The hole is sided for my 10mm hex (Socket) Maybe I should use my long beam torque wrench and try to turn it. I got 3 calls to help #s but you know how that works!
Post by sarge707 on Aug 1, 2011 11:39:21 GMT -6
I have 6 helmets-I told him to keep it.
Post by sarge707 on Aug 1, 2011 11:37:34 GMT -6
The opening (center ) Fits a 10mm Hex socket. I wonder if it is supposed to unscrew?
Post by sarge707 on Jul 31, 2011 15:57:55 GMT -6
Ok I have got every thing off my reverse trike rear wheel except the black right swingarm piece that connects to the axle. It will move back and forth but how do I get the wheel off? The center hole fits a hex bolt BUT is that the way because I don,t want go round out that hole. Can,t ride it until I replace the Out of Round Tire!! Attachments:
Post by sarge707 on Jul 30, 2011 15:51:47 GMT -6
Ok I have got every thing off my reverse trike rear wheel except the black right swingarm piece that connects to the axle. It will move back and forth but how do I get the wheel off? The center hole fits a hex bolt BUT is that the way because I don,t want go round out that hole. Attachments:
Post by sarge707 on Jul 29, 2011 16:09:58 GMT -6
Great, I hope this turns out to be a Great little trike! It will turn heads like the Spyder does!
