Post by dcooke on Jun 11, 2010 5:49:35 GMT -6
i found a brand new carb on ebay for 35 bucks. Im wondering if i should just buy it the drain all the fuel and start from scratch. If that fails then get rid of the scooter or take my 800 dollar problem to the shop for a hefty fee. so frustrated
Post by dcooke on Jun 11, 2010 5:31:16 GMT -6
is there also a way to add the amout of air getting to the engine?
Post by dcooke on Jun 11, 2010 5:15:23 GMT -6
The first time i took the carb apart the needle was in tight, but now it freely moves. I took the carb apart twice trying to figure it out ill take it apart again and check for dirt and in the gas tank this afternoon
Post by dcooke on Jun 10, 2010 18:36:46 GMT -6
gas keeps coming out of my air filter conpartment so the only thing i can think of for the stalling is the carb is over flowing into the air filter i dont understand what can be clogged?
Post by dcooke on Jun 10, 2010 16:55:07 GMT -6
i guess the problems are never ending with this thing. no it wont start and i have gas leaking from my air filter compartment
Post by dcooke on Jun 10, 2010 16:28:46 GMT -6
i just finished cleaning the carb. It runs in idle but when i go to ride it and give it gas it stalls. Is this lack of air?
Post by dcooke on Jun 10, 2010 10:17:08 GMT -6
OK i know where that is. The flow should point down right? I know on mine it points up towards the gas tank. Sorry for all the questions i have no idea about working on this stuff so im learning as we go
Post by dcooke on Jun 10, 2010 6:28:35 GMT -6
Ok is the fuel filter the circular thing that the two hoses connect to? it says flow with a arrow on it. I will pull the carb after work.
Post by dcooke on Jun 10, 2010 5:29:28 GMT -6
ill clean the fuel filter too. Is that located on the carb? and the fuel isnt the original fuel but he did fill it with regular when i picked it up he said he didnt know until after that it had to be premium.
Post by dcooke on Jun 10, 2010 5:28:02 GMT -6
when i changed the plug yesterday it started right up..then lastnight i wanted to let it run and it wouldnt start, i dont know if it being hot from the sun has anyhting to do with that? Im going to attemp to clean the carb today when i get home
Post by dcooke on Jun 10, 2010 5:26:44 GMT -6
no i only used 1oz
Post by dcooke on Jun 9, 2010 16:34:45 GMT -6
It does eventually die after being in idle for like ten minutes. It begins to die when i give it gas unless i give it quick burst. I but SeaFoam in with the gas to help clean the carb and stuff to see if it does anything. More smoke comes out of my exhust since its in there so it seems to be burning stuff off. Is there a quicker easy way that you know of to fix this?
Post by dcooke on Jun 9, 2010 15:26:08 GMT -6
If it stalls when i give it gas while its idle would that still be the problem? it starts right up just stall while idle or when i give it gas
Post by dcooke on Jun 9, 2010 15:22:04 GMT -6
ok thank you. If it stalls when i give it gas while its idle would it still be that?
Post by dcooke on Jun 9, 2010 12:28:07 GMT -6
OK im making progress..I replaced the spark plug with a new one and gave it a kick and it started right up. I let it just sit idle for about ten minutes then started giving it gas..It was fine for about 15 mins. then it started to die down alittle bit and go back up then finally stalled. No when i start it up itll run then stall.
