Post by eivad11 on Sept 21, 2011 0:54:15 GMT -6
good idea thats what i was thinking. well i have to find a bung to weld in there. any ideas on the size i can use
Post by eivad11 on Sept 20, 2011 1:39:06 GMT -6
i wish my tank was like yours straight so i can fit that piece n there
Post by eivad11 on Sept 14, 2011 23:15:35 GMT -6
with that nipple u screwed into the tank how high does it go into your tank
Post by eivad11 on Sept 13, 2011 2:40:58 GMT -6
the screws that hold onto my petcock on mine go into the tank and gas is exposed to them, can i just screw them back into the tank w/o the petcock and run a fitting threw the filter hole.
speedo
by: eivad11 - Sept 5, 2011 2:11:25 GMT -6
Post by eivad11 on Sept 5, 2011 2:11:25 GMT -6
just spray it with lube, i had the same prob
Post by eivad11 on Sept 1, 2011 23:49:47 GMT -6
bump
Post by eivad11 on Aug 30, 2011 2:27:47 GMT -6
i have a 2002 moskito and would like to put a brighter bulb in that, i have just that big bulb that does nothing for lite, do u have to rig up a switch to turn on the hid light or can the wire from the old be used. also will it burn my plastic
Post by eivad11 on Aug 28, 2011 15:29:47 GMT -6
on a scooter do u have to change the petcock every so often
Post by eivad11 on Aug 27, 2011 19:48:08 GMT -6
yeah i was seeing if i can update my gauges with yours and even the light set up, what style are your lights
Post by eivad11 on Aug 27, 2011 1:42:07 GMT -6
i hope so too, it was hard to find that gas cap, it looks like i can interchange parts with my bike with yours
Post by eivad11 on Aug 26, 2011 1:59:25 GMT -6
i know these batteries called ballistic, lead free and weight like 2 pds and half the size
Post by eivad11 on Aug 25, 2011 22:10:54 GMT -6
i meant i was having the problem straight
Post by eivad11 on Aug 24, 2011 23:24:54 GMT -6
well i have a gas cap thats bad n stalls the bike i think, oncew i get the cap on fri i will hope this fixes the prob
Post by eivad11 on Aug 24, 2011 21:35:33 GMT -6
can having a bad gas cap cause you to stall cuz if the vacuum
Post by eivad11 on Aug 22, 2011 21:48:14 GMT -6
what does it help when u block off the vacuum of the petcock
