Post by lougaro on Nov 21, 2011 16:35:18 GMT -6
Thanks for your input alleyoop! Lou
Post by lougaro on Nov 19, 2011 20:07:55 GMT -6
Hey guys, thanks for all your help. I removed most of the plastic to look for any loose/broken wires. A real PITA. After a half day looking and finding nothing, I was ready to give up and pay someone to fix it. I decided to look closely one more time at a connector with wires leading to the fuse block, right below it . I noticed that one of the wires (brown) was loose in the connector and was almost out. I pushed the wire back in tight and the problem was solved!! I am happy that I found the problem myself, but pissed because that connector was easily accessible without the removal of any of the body plastics. Anyway, I am tired and I'll reinstall the plastics tomorrow. Thanks again guys.
Post by lougaro on Nov 18, 2011 10:49:54 GMT -6
Thanks guys, I'll get started today.
Post by lougaro on Nov 17, 2011 17:58:07 GMT -6
Hi, I am new at this and I have a familiar problem with my 08 SunL250-22. After 850 miles the headlights and tail lights stopped working. I changed the 4 fuses, checked connections under fuse box but nothing. Later, the horn, break lights and passing hi beam light stopped working also. The hazard lights and directional signal lights still work. Are there other fuses or connections I should check? Please help!
Post by lougaro on Nov 17, 2011 14:59:41 GMT -6
Hi, my problem is just the opposite, the headlights and taillights no longer go on when I start the scooter (SunL 250-22). And later the brake lights stopped also. Is the problem the same shorted diode? Please help.
