Post by bear on Aug 14, 2011 2:03:59 GMT -6
The rectifiers do get warm. Be sure to check that you have good electrical connections to the rectifier and that all the contacts look good. If you have any bad connections (not a solid ) that will cause the rectifier to over hear. Also if the rectifier can be mounted a metal frame, the frame will act as a good heat sink and draw off some of the heat.
Bear.
Post by bear on Aug 14, 2011 1:36:51 GMT -6
I have a JCL250A 2007 and can't get the seat to completely unlock. The key unlocks the side latch OK but the back latch remains locked. Any ideas?
Bear
