Post by brianky on Aug 25, 2011 12:10:07 GMT -6
ok, thanks.
Post by brianky on Aug 22, 2011 14:31:02 GMT -6
seeing how I have now removed all plastic, removed all wire loom and zip ties, spent about 8 hours now looking this thing over, trying this wire here and that wire there, I would gladly put a new harness on it.
Post by brianky on Aug 22, 2011 12:42:00 GMT -6
sorry, yes, when signal is turned on, the left blinks as it should, but everytime it blinks, the starter engages. The right turn signal works as it should.
Post by brianky on Aug 22, 2011 12:40:50 GMT -6
Thanks, we have done all of that. All connections are as they should be, I have replaced the CDI, the volt reg and the starter relay. most connections under the plastic are different and can not be crossed.
Post by brianky on Aug 18, 2011 12:46:24 GMT -6
Hi all, here's a good one. I have a new (showing .4 kmh) Taotao 50cc, the start button does not work, but if you pull on either brake handle OR use Left turn signal, the scooter starts. And after starting and running, if you use either brake or the left turn, the starter engages. I have removed all plastic, I have traced the harness from one end to the other. I can not not find any shorts, loose connections or plugs. I called Taotao, they were very rude. They have sent 3 harnesses now and none are the right one. Has anyone ever heard of this before or know where I can order the correct harness? Thanks
