Post by wahlong on Oct 11, 2011 13:09:20 GMT -6
thanks ill try valve gap today
Post by wahlong on Oct 6, 2011 12:53:51 GMT -6
i am a auto mechanic ,my friend baught a dash 50 for his son and it runs bad so i agreed to look at it i believe it is fuel starved but i have done all kinds of things ,this is what happens ,take off and with in 100 yards dies and stalls ,waite a min and you can repeat this,new fuel lines and petcock ,oh i am convinced it is fuel starved ,on the origional carb i adjusted the float ,drilled out the seat to flow more fuel ,replaced carb with a new one $24 ,figured what the heck! same symptoms ,driven it with exhaust removed ,thinking it was some kind of guvinor disconnecter speedo ,still same symptoms wont go above 20 mph usually,help! please,bill
Post by wahlong on Sept 26, 2011 11:01:50 GMT -6
i have the same problem on a new dash 50 chineese scooter ,have you discovered a fix for it ,i have ran my fuel line straight and that still didnt fix it ,i am thinking of adding a eletric fuel pump
