Post by Thebatman on Nov 2, 2011 5:52:34 GMT -6
Hey guys. Well, the order is on it's way. According to the port program this will take her to a 86.4cc. .... Went with the 50mm and 44mm crank. Sure hope we have some 2t builders around.. ;D.. Any and all input is greatly welcomed
Post by Thebatman on Oct 20, 2011 15:00:53 GMT -6
Hey guys.. I was told the oem tooth count is input shaft is 13t, output shaft is 45t Intermittant is at 13t..40t.. The set of secondary gears i have is 15/42.... Am i wrong in thinking that each gear swap(primary and secondary) should yield about 4mph for each?
Post by Thebatman on Oct 20, 2011 11:38:27 GMT -6
Well a 15/42 gear sets gives you a 2.80 ratio. What is your current gears tooth count? I went from 13/40=3.08 ratio to 16/37=2.31 ratio Alleyoop I actually have no idea of the actuall tooth count. I may be able to text a friend on the coast to see if he happens to remember the count. I haven't ever removed the cover to even see. I had wanted to tho cause i have a honda 125 2t engine that has a 6:1 wheel/bell ratio and it's rummered that the gears MAY swap, but of course i haven't went to work on it to see.
Post by Thebatman on Oct 19, 2011 16:05:38 GMT -6
Here is a pic of the intake tract porting i needed to do on the zx with the last build i done. WHICH BTW, was my very 1st build.. ;D Here is the finished product.. This piece here is a 7" extension that i had made but havent been able to ever install. With this build i plan on FINALLY getting my 7" stretch. A pic of the boost port work that i did here. It was a big difference from the oem port. Here is a few pics .....AGAIN.... of my lil baby. As you can see in the pics i had the seat redone with a lil red thrown in. She has alot of visual mods compared to the oem for sure. I do have led accent lights throughout(red of course), Polished/vented cvt cover, Black paint. I also installed a '08 kymco S9 wheels/brakes, complete suspension upgrade. Removed the "mud flap", removed bulky turn signals(wired for euro's). Installed handgrips, TTO tach.. I know i'm not listing all.. ;D There does seem to be a low amount of "kymco" scoots here.(but of course,there isn't alot of them unless your @ the kymcoforum... ;D) Even tho, i do hope to get your valuble input on this project of mine. Is there any "gear" ppl here?.. I have a set of secondary gears to install also but IDK WHAT i should really shoot for. I have a 10.5:1 ratio on the wheel/clutch bell ATM(have a set of 15/42?). I had read some time ago that a 8.5:1 would be ideal. Lord knows i haven't mastered this tuning stage at all yet. Thanks for looking at this thread guys. ;D
Post by Thebatman on Oct 19, 2011 5:28:15 GMT -6
Hey guys. I had posted a few pics of my zx in the pic section, i will place several in htis thread... IF this is where it belongs.. I have a few questions for you guys.... Does anybody "build" or do you just upgrade? I am looking at a kit from carlos and jiangwayne... Looking at either a 48mm kit or the 50mm kit with a 44mm crank.(instead of "72cc", for an extra $20-25 i can go up to the "80cc"(4cc from the 50 kit...4cc from the crank for $20 sounds real good to me... ;D Has anyone here used either kit? I have a L.V ZX exhaust that kindof worries me also. This pipe SHOULD be ok up to 90cc but IDK.. Can i get your input on this post?....48?...50 with a 44 crank? Input on either kit? pipe? Thanks guys for any input/advice you may share with me.
Post by Thebatman on Oct 9, 2011 7:30:04 GMT -6
Thanks Bashan... I will get some pics up today
Post by Thebatman on Oct 8, 2011 5:23:09 GMT -6
HEy guys... My name is Larry... A.K.A thebat man... I am registered on several other forums and am sure they are several of the same ppl here,(maybe i shoula changed my name. ;D) I have several Kymcos in the house.. I own a kymco agility L.C S9, and my baby.. My ZX.(which is broke ) I hope to keep learning about these scoots.(the S9 and zx are built by me). Of course the ag is a "gy6" and i just cant leave it alone either.. ;D Hope to make a few new friends and hopefully help out...if I don't ask to many questions... ;D
