No Idling
by: vic57 - Mar 7, 2012 22:48:32 GMT -6
Post by vic57 on Mar 7, 2012 22:48:32 GMT -6
I tried it. But, after 80 miles driving, the engine cut out again. After that, I can't start my engine again. By the way, when I was driving last time, I felt that my scooter lost power little bit, and temperature was over normal. When I checked spark, it was very poor. I replaced the ignition coil, nothing change. What can I do else?
No Idling
by: vic57 - Mar 2, 2012 2:33:40 GMT -6
Post by vic57 on Mar 2, 2012 2:33:40 GMT -6
Thanks, but before I asked about my problem, I clean carb, adjusted pilot screw, replaced enricher. After your advice, I adjusted valves. No result. Now details: when I first start I have to keep giving it throttle to keep it running, stop throttle it- engine is die. When engine is warmed- same, no idle. If I'm driving on the street I have no problems: good power, everything is working perfect, but if I stop on the light, engine die immediately. One more thing- now I can't start engine by remove control, it's not working. Do you have any idea what happened?
No Idling
by: vic57 - Feb 22, 2012 14:33:08 GMT -6
Post by vic57 on Feb 22, 2012 14:33:08 GMT -6
According your advice I adjusted valves, but no result.
No Idling
by: vic57 - Feb 21, 2012 14:18:05 GMT -6
Post by vic57 on Feb 21, 2012 14:18:05 GMT -6
One day I lost idling. In driving position no problem, but if scooter get neutral position, engine is cut out.
Timing
by: vic57 - Nov 5, 2011 23:39:15 GMT -6
Post by vic57 on Nov 5, 2011 23:39:15 GMT -6
Thanks, it was very helpful information!!!
Timing
by: vic57 - Nov 5, 2011 16:48:00 GMT -6
Post by vic57 on Nov 5, 2011 16:48:00 GMT -6
camshaft's bearing was wrecked, I got new one and start thinking for timing, like I did on my cars.
Timing
by: vic57 - Nov 5, 2011 14:32:16 GMT -6
Post by vic57 on Nov 5, 2011 14:32:16 GMT -6
I have scooter SL250-22, YY250T. I don't know, how setup timing.
