Post by calmissile on May 14, 2012 14:33:44 GMT -6
Post by calmissile on Mar 12, 2012 18:05:33 GMT -6
Thanks for the advice. Prior to seeing your message, after several hours of searching the on line suppliers I finally found what I need. They have the correct (different) mounting ears and are adjustable to boot! Anyone looking for the correct shocks are likely to be mislead by all the on line ads. Here is what I found that seems to be the correct part and certainly are the right price. LOL. www.ebay.com/itm/270851158813?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Post by calmissile on Mar 11, 2012 23:04:54 GMT -6
I purchased a used 2008 Jonway YY-250T with only 300 miles on it. In the process of troubleshooting a cooling problem I removed the rear side panels to get access the engine and discovered a loose (upper) bolt on the frame that appears to be for the left shock absorber that is missing. It also appears that the right and left shocks have different mounting ears on them. A search of all the parts places on line only show one shock style. The sketches on the Jonway web site show what appears to be the right shocks (different mounting for left and right). See sketch for reference. www.jonwayusa.com/English/PartsShow.asp?id=90Do any of these on line parts places know what they are doing? They all seem to copy the same catalogue and none of them have the correct part listed for the left shock. Also, the existing shock installed on the right side appears to be adjustable with a spanner wrench for spring pressure. It this the original shock for the bike and are the replacements the same thing?
Post by calmissile on Nov 30, 2011 0:26:57 GMT -6
I have a Jonway YY250-T and am changing the forks (front shocks). Nowhere can I find the specs for how much fork oil and of what weight fork oil I should use.
Also I can find no manual on this scooter. The Haynes manuals do not list this model, so where do you find a manual on the bike itself? I guess manuals are available on the engine but it doesn't do any good for the frame/chassis/plastics/brakes/etc. The owners manual does not even match the scooter.
Was there ever a service manual written for these? The helix manual is not the same chassis.
