Post by hozer on Mar 31, 2012 17:10:13 GMT -6
UPDATE!!!
I took a look at motor again and saw the the cylinder goes up like the Helix picture you have.
It sez this on the alum. Plate:
Engine Family: Jonway 244cc BJNCO.25FG
IDLE 1700
thats It!
Now I need to set the Idle its at 1000 instead of 1700. So how do I go about getting rpm and and how do I change the plug?
Post by hozer on Mar 29, 2012 21:58:08 GMT -6
HAHAHA!! Well if your has a remote those can cause problems restarting your scoot. If the sequence used to start them and shutting them down is not right(HEHE). Alleyoop Kinda confused. I dont use the remote at all. So if I turn off the battery I could hurt the scoot??
Post by hozer on Mar 29, 2012 20:52:13 GMT -6
Yep, the alarms and remotes on the scoots that have them usually will drain the battery just sitting there. A lot of the folks unplug the them they find that they are more problems than they are worth. But glad you found a way so that it does not drain your battery. Alleyoop What other problems should I expect lol?
Post by hozer on Mar 29, 2012 20:27:15 GMT -6
Well I'll see if I can find out what motor tomorrow but I found out from a tech the reason the battery keeps dying. The reason it dies is because of the alarm. They have the same problem at the dealer. What they do is disconect the red battery cable. So what I did I put in a 20 amp on and off switch between the battery and the red battery cable. Now I was told the only reason the battery in the scoot is to start the scoot thats all. So as soon as I start the scoot I turn off the battery switch and the lights and everything else is still working. Kool Eh? I also have an extra battery under the seat just in case the main battery fails. It sucks not having a kick start on this model of scoot. Cya guys!!
Post by hozer on Mar 28, 2012 20:14:37 GMT -6
Thanks for the Welcome Bud Well not sure what type motor I do have The manual sez Jonway 2011 MC-54-250. I saw a video of a scoot that look like the on I have. Here is the link. Put slider at 3/4 over and he will say the type of motor. Is there a sure way of finding out what motor type of motor I have. Here is the link I saw....... scootdawg.proboards.com/index.cgi?board=200cc&action=display&thread=48302Hope that helps Thanks
Post by hozer on Mar 28, 2012 18:24:50 GMT -6
Well I have a new Jonway YY250TT and what I heard its the same as a Roketta. It's time to get rid of all factory fluids. What I need to know is how to change the oil, Change oil filter and fuel filter and gear oil and change spark plug. So is there a repair manual for I can do all the required maintenance?
I live in Denver and there are no parts places where I can get the parts at!
Thanks in advance
