Post by ronscycle1 on May 18, 2012 23:45:15 GMT -6
JONWAY JUNK
Post by ronscycle1 on May 16, 2012 11:19:23 GMT -6
im going to put a relay in insted of the diode, need to know why i only have 6 volts coming right out of the regulator ,red wire reg side,with the red wire out of the coupler and coupler pluged in has a new regulator regulator on it
Post by ronscycle1 on May 15, 2012 19:58:46 GMT -6
has a new regulator on it now is there a way to check the regulator
Post by ronscycle1 on May 15, 2012 14:24:44 GMT -6
i have 26 ac volts at stator yellow wires at idle and about 85 to90 ac volts at 5000 rpm . with everything diconnected except regulator if i take the red wire out of the regulator side of the coupler and pluged couple in then put volt meter on the red wire and green to ground of the tester shouldnt i get about 13 or 14 dc volts? i get only like 6 Help Plz thanks ron
Post by ronscycle1 on Apr 1, 2012 10:35:17 GMT -6
is the headlight supposed to come on when ya turn on the key or wait till started ?
Post by ronscycle1 on Mar 31, 2012 13:00:28 GMT -6
its horizonel engine , batt wont charge
Post by ronscycle1 on Mar 29, 2012 17:31:46 GMT -6
hi , i need a shop manual for a 2007 jonway yy 250 t , having charging problems , can you help please thx ron
