Post by itsmedad4u6 on Mar 30, 2012 20:19:25 GMT -6
You have a very good picture of what i have in here... I have copyed it.. how do I post it for you to see? it is a LanHai, horizontal, and shows the fill tube and the breather tube very clearly on the clutch end of the assembly. thanks for you help Sir:
Post by itsmedad4u6 on Mar 30, 2012 19:51:37 GMT -6
Sir: this may sound strange, but I have a big plastic oil fill plug just behind my shock, and right adjacent the wheel. It is just like my engine oil plug but no dip stick cast into it. Mounted just above it is a breather tube.. about 3/8" dia. about 4" long. it is routed right down beside the fill hole. I'll be takeing my cover off again tomorrow, and will try and discover the fill and drain bolts, you so kindly displayed to me above. You have a nice evening and thanks ever so much for this Sir:
Post by itsmedad4u6 on Mar 30, 2012 19:34:17 GMT -6
Rick.. thank you Sir: In time i'm sure I'll get this right....
Post by itsmedad4u6 on Mar 30, 2012 18:51:16 GMT -6
Post by itsmedad4u6 on Mar 30, 2012 16:12:05 GMT -6
I have done this one time, but I do not see it anywhere. I just received my JCL MP 250A - yy250T from Killer MotorSports in Fort Worth Texas... I live in Spring Hill Fla... It's a 2007, so it is five years old right now. So far it looks new, drives like new, it's wonderful... I have a full 8 miles on it. Waiting for papers to get my plates... I do have an issue that revealed itself about 30 minutes ago.. My alarm quit functioning from either key.. It worked beautifull , I even found out how to programm it... Now all of a sudden it is no longer functional.. The lights work when you push the buttons on the key ring... but the scooter does nothing...
Post by itsmedad4u6 on Mar 30, 2012 15:10:38 GMT -6
I have a new (3 days) yy250t.... jcl mp250a. I pulled the oil plug from the bottom and changed it before i ever run it. Changed the antifreeze... used Dexacool.. remember to squeeze the hoses to prime it. My gear oil is an issue. the manual says to fill it up. I have a big plastic plug on the top of the clutch, I have put quit a bit of oil into it and it is still not full. I just stopped till i find out something about it. ANYONE KNOW ABOUT FILLING THE GEAR OIL ON THIS... PLEASE....
