Post by mdholmes on May 22, 2012 3:42:57 GMT -6
i removed the flywheel and stator cleaned and sanded and got spark for 2 days. when no spark returned i checked ac volts on red-black wire from stator and got 33-40 vac.i sprayed elactrical cleaner in inspection hole and got 44vac and got spark. while running i get 76 vac. probably needs stator, or am i missing something?
Post by mdholmes on Apr 25, 2012 4:06:36 GMT -6
to determine no spark iused a new plug grounded on engine to frame ground. this ground is on the head of the engine on this model. ground is good.
Post by mdholmes on Apr 22, 2012 13:29:05 GMT -6
agreed on lose the alarm that is why i am chasing harness and am conciderating new non-hacked harness.it came with the alarm or it wouldn't have one. im just trying to eliminate it properly.plug is new and fits properly on boot. once again thanks
Post by mdholmes on Apr 22, 2012 5:36:36 GMT -6
i replaced coil and cdi with oem. sketchy wiring on remote was pointing to harness but stator also makes sense. i will test that today along with chasing the harness further. thanks.
Post by mdholmes on Apr 21, 2012 18:33:22 GMT -6
i have a Yamati rx150 sometimes spark and other no. when it runs there is no issues everything works. i have changed cdi and coil to no avail. this scooter came with a alarm/remote start. i am thinking about replacing the wiring harness to get rid of the alarm.am i missing anything obvious?
