Post by flakdodger on May 4, 2013 11:43:28 GMT -6
Yes it is a factory tach. checked all of the wires just not sure what is supposed to go where. Nothings is broken or disconnected.
Post by flakdodger on Apr 26, 2012 1:00:17 GMT -6
My son picked up a 2008 Velocity 150-06. It has the alarm system and auto starter which I am not sure is necessary. Everything is working on the scooter fine.
The problem I have run into is that when you turn the key on the tach pegs and stays there with the engine off and also while the scooter is running. I have looked at all of the wires behind the gauges and do not see any problem. I found the three wires that connect to the tach and when i disconnect the black wire the needle drops back to zero.
I have looked at the wiring diagram that is here on the site, but am not sure what I should be looking for. Has anyone had this problem and can help correct it.
