Post by derekio on May 17, 2012 15:19:24 GMT -6
voltage. i have voltage at the switch> is there a pinout drawing somewhere that i can jump across and rule out the switch being bad>
Post by derekio on May 9, 2012 6:36:50 GMT -6
checked it. I've also checked about every connection on this thing. also,If I can start it by crossing solenoid, then that rules out weak battery doesn't it? I thouggt maybe key switch was bad, but I get light and horn when I turn key on.
Post by derekio on May 8, 2012 16:37:13 GMT -6
znen-lance 150cc. I can't get it to start from the switch. i can cross the solenoid, and it starts right up. what i've tried: replaced solenoid replaced brake light switch replaced right hand switch cluster(run-off, and push to start button) Ive checked inline fuse Ive made sure scooter was on center stand when trying to start.
the headlight, turns, horn, brake light, all work
turn key on, hold brake, turn switch to run, and push yellow start button...nothing..no clicking..nada
but cross the solenoid and it starts right up
