Post by derekio on May 8, 2012 16:37:13 GMT -6
znen-lance 150cc. I can't get it to start from the switch. i can cross the solenoid, and it starts right up. what i've tried: replaced solenoid replaced brake light switch replaced right hand switch cluster(run-off, and push to start button) Ive checked inline fuse Ive made sure scooter was on center stand when trying to start.
the headlight, turns, horn, brake light, all work
turn key on, hold brake, turn switch to run, and push yellow start button...nothing..no clicking..nada
but cross the solenoid and it starts right up
Post by Alleyoop on May 8, 2012 16:42:32 GMT -6
Have you checked the Wire going to the SOLENOID from your Start Button. Alleyoop
Post by sprocket on May 8, 2012 22:08:30 GMT -6
I agree sounds like a bad start button or loose wire
Post by derekio on May 9, 2012 6:36:50 GMT -6
checked it. I've also checked about every connection on this thing. also,If I can start it by crossing solenoid, then that rules out weak battery doesn't it? I thouggt maybe key switch was bad, but I get light and horn when I turn key on.
Post by Bashan on May 9, 2012 9:21:40 GMT -6
Post by derekio on May 17, 2012 15:19:24 GMT -6
voltage. i have voltage at the switch> is there a pinout drawing somewhere that i can jump across and rule out the switch being bad>
Post by Bashan on May 17, 2012 15:51:09 GMT -6
Try going through the solenoid/starter diagnostics. Here's the ignition switch testing but that shouldn't cause this. If you turn on your switch and have brake lights then you'll have power to the start button. You'll see what I mean on the diagram in the tutorial. Rich
Post by azwinter on May 18, 2012 16:07:24 GMT -6
I have a problem with starting my scooter too. I cannot find out where the battery is located on my SYM fiddle ll scooter. Anybody know? azwinter
Post by rob63 on May 18, 2012 16:19:46 GMT -6
I have a problem with starting my scooter too. I cannot find out where the battery is located on my SYM fiddle ll scooter. Anybody know? azwinter On the floor where you put your feet should be a plastic flap held in by, I think, four screws. The battery is under that flap.
Post by azwinter on May 18, 2012 16:26:08 GMT -6
I just got the answer. The battery on my SYM is located under the floor board. In case anyone else has a similar problem.
Post by azwinter on May 18, 2012 16:27:31 GMT -6
Thanks Rob63. You are absolutely correct. Now I know this forum really works.
Post by azwinter on May 18, 2012 16:29:37 GMT -6
Wow! information from the UK. How great is that! I am located in Arizona. Thanks again
Post by variant2 on May 19, 2012 22:51:17 GMT -6
Is the GY6 starter solenoid the same as starter relay?
Post by sprocket on May 20, 2012 11:31:52 GMT -6
yes same thing..but on some scooters there is a second relay...which is a relay..not a solenoid
