Post by lennie11b on May 25, 2012 12:04:13 GMT -6
WELL the voltage regulator is getting hot and my battery is not charging so im going to install a new 6 wire 2 plug regulator hope that takes care of it if not ill cuss and hollar some more and get a new stator any advice about regulators would be helpful thanks
Post by lennie11b on May 25, 2012 9:03:37 GMT -6
Well i have been having problems with my running lights. High beams work off the battery so i found some yellow wires that only have juice while the engine is running. Heres what my meter read first at idle 8ac then down to 4ac then to -8dc so that blew my mind any thoughts
Post by lennie11b on May 24, 2012 21:39:26 GMT -6
yeah i have a switch like that a little differnt but same. When i switch it on to passing the lights work. but do not the other way.
Post by lennie11b on May 24, 2012 11:25:27 GMT -6
I can turn on my high beams with the engine off and key switch on. The two small lights under my high beams that should come on with the running lights do not come on with the headlight switch on low and the key switch on. BUT i think they are not battery powered and should run with the engine but i think they are not getting enough power so what do you guys suggest now THANKS
Post by lennie11b on May 24, 2012 10:27:01 GMT -6
NEW discovery don't know if it helps. Low beam wire brown turns into Brown/White and then turns in to yellow. I went back toward my seat area and found a bunch of yellow wires. With the engine off no power go to them but with the engine on with my test light it's very very dim so could that be the problem remember im a newbie to this scooter and the scooter world thanks for the help
Post by lennie11b on May 24, 2012 9:58:14 GMT -6
I just checked my key switch it has power but the connectors that go to the head lights only the blue wire has power. The brown wire that goes to the low beams has no power. then i went back to the tag light which use's a brown wire does not have power. i checked grounds they are all in i really have no clue how to get this power back going through brown again
Post by lennie11b on May 23, 2012 21:40:52 GMT -6
All lights work off that switch. It had this problem when i bought it ill try to run down this wire. Would it be a good idea to bypass or what do you suggest Thanks
Post by lennie11b on May 23, 2012 10:47:00 GMT -6
I have a 2008 Jonway 150cc with 80 miles. All my signals work and brake lights work hi beams work off a switch but the tail lights and low beams and dash lights are not working. Im new to the scooter world this is my first one. I changed the headlight switch but now i need a push in the direction i should check next any help would be awesome
