Post by esstallion on Jul 9, 2012 17:49:30 GMT -6
Rings are at 120 deg apart with nothing in line with the pin. It just wants more gas after 40-45 mph. What size jets are good for a 100cc big bore kit?
Post by esstallion on Jul 9, 2012 16:10:48 GMT -6
Do like me and buy a new carb an ebay! They are only like $25 and you dont have to mess with it.
Post by esstallion on Jul 9, 2012 16:02:48 GMT -6
I fixed it, not sure what was wrong. I spent the $65 and got the 100cc bigbore kit and put it on. Runs like a champ! Does about 40-45 mph. Wants to go faster but i think i need to rejet the carbs. What size should i use?
Post by esstallion on Jun 30, 2012 8:49:29 GMT -6
I think the clutch and variator are correct. I took them apart and cleaned them and with the wheel off the ground the tire spins like it should. and I would say the chain is on because the valves move in time with the piston.
Post by esstallion on Jun 29, 2012 7:37:51 GMT -6
Scooter Doc, If I was out in the timing would this thing run as smooth as it does? It runs smooth but just wont pick up power.
Post by esstallion on Jun 27, 2012 19:53:47 GMT -6
When i suck on the vacuum line to the petcock fuel comes out at a steady stream. When i crank the starter fuel just spits out, Does this prove a vacuum leak or is that normal?
Post by esstallion on Jun 27, 2012 15:28:41 GMT -6
I will give it a shot if the new intake dont work.
Post by esstallion on Jun 26, 2012 6:03:14 GMT -6
Im not sure how it ran before, i got it given to me like that. The timing is set to small hole aligned with head and big hole up with flywheel set on timing mark, TDC. with the wheel of the ground it revs fast. I am hoping the intake is to blame!
Post by esstallion on Jun 25, 2012 17:14:46 GMT -6
I just rebuilt the top end on the scooter. Valves are adjusted and carb is new. The stupid thing will not go faster then 15mph. It runs smooth with no problems but it only goes 15mph. I have 2 carbs and they both do the same thing. The only thing left that looks bad is the intake is cracked looking so i ordered a new one. Anything else you can think of that would make it only go 15mph? thanks.
