Post by lhumpolick on Jun 28, 2011 23:01:46 GMT -6
Speaking Of lights I ran into a problem last year when i had a trunk put on my 150 scooter it tuns out it blocks the tail lights What i did was to get 24 of the brightest lignts i could find i set up 3 colums of 4 on each side of the trunk lid i used the center 4 for turn signal the out side for the brake and running lights i used a pc monter exct cable so i disconect them when i remove the trunk no other relays etc.. i will try to get photos at a later date. I ded this bewcause i almout got hit by a truck. my best advice is to check you lighs after you mount anything over the rear tail lights.
