Post by kbonanny on Sept 12, 2012 4:00:11 GMT -6
Thanks, I thought I was losing my mind! This does have the light switch, but the only power to it is on the "flash" (high beam flash) button, so it has lost power somewhere. Any pointers on likely locations??? Thanks for the help! Kirk!
Post by kbonanny on Sept 8, 2012 12:52:06 GMT -6
I forgot to mention that I found 2 20A fuses, and both the fuses and connectors electrically check out ok.
Post by kbonanny on Sept 8, 2012 12:50:59 GMT -6
Hello, I am an ASE Master Technician who has had the unfortunate situation of encountering one of these scooters, and I need help! This scooter lost the headlights, and potentially more. I was working off of the wiring schematic and can not find the diode coming off of the manostat (red wire). I have traced everything I could find on the schematic and have not discovered the problem(s) as of yet. I read through a number of older posts and still have not found the answer, though I will be soldering the connector to the rear lights. Any and all help would be greatly appreciated! Thanks, Kirk.
