Post by griffin123456789 on Apr 3, 2013 17:19:20 GMT -6
If you installed the PLUS-4 MM crank and did not add any gaskets you are running at really high compression. I would add two or three base gaskets at the bottom of your cylinder. If you do not you could cause serious damage.
