Post by captonzap on May 18, 2013 16:40:58 GMT -6
If you can post a pic of your dash with the holes circled so we know what you're talking about it would help a lot. We did have a guy on the forum with a Vento and here is a pic of his dash. I circled what may be similar to what you're in question about. I think that's the gas gauge above them. This may be an aftermarket dash though, I'm not sure.
Sorry for the delay. I don't have a way to take or post pictures, but the one shown is the same one I'm asking about. The three holes circled have push on/off switches under each hole. I haven't found anything they affect, but then I may not have looked in the right place. Yes, the gas gauge is directly above the holes, and it is a digital masquerading as an analog gauge. There is some fine marking under each hole, cast into the plastic, so I am guesssing that it is OEM. Thanks for the effort on the pictures, CZ
Post by captonzap on May 10, 2013 9:19:29 GMT -6
On a 2006 Vento GT5 instrument cluster housing, there are three small holes in the plastic housing, under the center mounted gas gauge, and they seem to have a push on/push off switch under each of them. Does anyone know what function they serve? Thanks, CZ
Post by captonzap on May 5, 2013 8:49:26 GMT -6
see? i toldya, im learning everyday here in scootdoc, Alley, next time ill show you the internal parts of the liquid cooled, ECI, fuel injected japan scoot, just so you know. lol Man, I gotta school ya all again? ECI= electronic controlled ignition. works in conjunction with the EFI= electronic fuel injection. ;D Roy There you flat landers go again. The English speaking portion of the world refers to that as the TCI. (Transistor controlled ignition). Chalk it up to regional dialects, I guess. CZ
Post by captonzap on May 4, 2013 9:46:20 GMT -6
Hello, Can anyone tell me the difference between these two style engines, both 50cc? VE157FM2A and TH139QMB One is on a Vento and the other on a Meitian. Do they both use the same CDI? Does anyone have an electrical schematic for a Vento GT5 50cc scooter? Thanks, CZ
