Post by billynew on Jun 1, 2013 16:40:47 GMT -6
Turns out there was a crack on the inner part of the flywheel where the key slot is so i have a new one and an assortment of keys. Do you know the exact size of the key?
Post by billynew on May 26, 2013 20:01:20 GMT -6
Yea i found it and tossed it because it was mutilated and thought it was a chunk from something else so of course i put the flywheel back on and hit it with an impact. tried to take it off this morning and the wheel wouldn't budge so tried a 3 point puller and and theres no room for the hooks so ill try a 2 point on the two inner slots of the flywheel hopefully i can get it off and get a key in it. Thanks
Post by billynew on May 25, 2013 22:02:34 GMT -6
I have a taotao powermax 150 that is fairly new. I had the nut on the end of the crank shaft rattled off, the magneto wheel came off, severed the stator wires, and fried it. I replaced the stator and now have fire on the plug but motor still won't crank. Is it possible that the wheel coming off would've made it jump time?
