Post by satexascoot on Aug 7, 2013 18:08:37 GMT -6
I've got this 50CC scooter I've replaced the following: a) New fully charged Battery 2) New and tested Starter 3) New Starter Solenoid. Now here's my problem. I get about 3 or sometimes 5 cranks of the starter and it acts like it's going to start and then all of a sudden the Starter Solenoid starts clicking and no cranking is occurring at all. if I remove the Starter and bypass the connections and directly connect the leads from the battery to the starter it works and spins fine. I can re install the starter, sometimes I get it to turn over and sometimes it just clicks at the Starter Solenoid. I can see where the grounds are connected to the chassis and I've double checked their connections and it seems fine. I'm really at a loss as to why it would at least crank a couple of times then start clicking at Starter Solenoid. Any suggestions would be greatly appreciated.
Post by satexascoot on Aug 7, 2013 17:47:21 GMT -6
Thanks Guys its all put back together and clean. Now on to this starting problem.
Post by satexascoot on Aug 6, 2013 20:44:44 GMT -6
Dippy51, thank you for that. It answered my next question, which was the float adjustment and the video covered perfectly. Any tips you guys use to adjust the float would be much appreciated as well. If you look closely at the picture I put a tee in it as well but I'm going to try the adjustment and see what happens.
Post by satexascoot on Aug 6, 2013 12:30:03 GMT -6
Alleyoop, thank you for the response. I'll search you-tube for a good video in taking off the carb. I'm looking at it now and the job does not seem to terrible. Thank you again for the response.
Post by satexascoot on Aug 6, 2013 7:04:33 GMT -6
Guys, I've got a problem on my 50CC Carb. When the scooter is running the vent tube on the side of the carb is dripping gas out of it. Well it's more like spewing it out. I know its supposed to be a drain but should the one pictured that is circled in red be plugged or connected to something? I've looked all over the scooter but cannot seem to find a place to plug it up to. Any help would be appreciated. MP Attachments:
